Stuartzm
Dec 25, 2018Aspirant
Netgear Powerline 1000 PL1000 - wifi access failing
Hi - My Netgear Powerline 1000 booster has worked fine I then got a new modem. Now I cannot get any devices (ipad &iphone) logged onto the signal despite that all the LED indicators are showing gree...
- Dec 30, 2018
Ok, i have got it running. I started from the beginning again, I replaced all cables, did factory reset on modem and netgear and got the ethernet cable to computer and netgear working, range extender is now also working. I don't really know what I did, but thanks Stephen B for your input.
Stuartzm
Dec 28, 2018Aspirant
OK, have done that but no difference, same message when I try to connect mac book via ethernet cable. I have also taken the modem back to my internet supplier and swapped it for another, gain same issues persist.
Stuartzm
Dec 30, 2018Aspirant
- StephenBDec 31, 2018Guru - Experienced User
I glad it's resolved.
