Carroda's avatar
Carroda
Tutor
Dec 01, 2015
Netgear R7000 with EX7000, extend the same wifi as acces point?
Hello,   Today i've bought a EX7000 to go with my R7000 wich I've had for about a year now. The reason for buying it, was to extend the Wifi network, so improve the area where the R7000's signal w...
  • TheEther's avatar
    Dec 01, 2015
    I believe you should be able to use the same SSID as the main network.  Just be sure to use a different channel.
    AFAIK, the EX7000 cannot simultaneously support a guest network in addition to the main network.  It would have no way of segregating the traffic while backhauling it to the router.
    You could probably use a second extender just for the guest network.
