Carroda
Dec 01, 2015Tutor
Netgear R7000 with EX7000, extend the same wifi as acces point?
Hello, Today i've bought a EX7000 to go with my R7000 wich I've had for about a year now. The reason for buying it, was to extend the Wifi network, so improve the area where the R7000's signal w...
- Dec 01, 2015
I believe you should be able to use the same SSID as the main network. Just be sure to use a different channel.
AFAIK, the EX7000 cannot simultaneously support a guest network in addition to the main network. It would have no way of segregating the traffic while backhauling it to the router.
You could probably use a second extender just for the guest network.
Carroda
Dec 03, 2015Tutor
Works like a charm now. Set the router to channel 2, the acces point to channel 7 (and a 3rd asus acces point to channel 12 )
All set to the same SSID and password. I've had a walk around, and it never appeared to even switch network, so I suppose its working then.
THe guest network isnt an issue, since its only really used in the livingroom anyway. But it was just something I was wondering about.
Thanks for the help!
