Carroda
Dec 01, 2015Tutor
Netgear R7000 with EX7000, extend the same wifi as acces point?
Hello, Today i've bought a EX7000 to go with my R7000 wich I've had for about a year now. The reason for buying it, was to extend the Wifi network, so improve the area where the R7000's signal w...
- Dec 01, 2015
I believe you should be able to use the same SSID as the main network. Just be sure to use a different channel.
AFAIK, the EX7000 cannot simultaneously support a guest network in addition to the main network. It would have no way of segregating the traffic while backhauling it to the router.
You could probably use a second extender just for the guest network.
rolldog
Mar 23, 2016Aspirant
Is this still working for you? Also, are you having IP addresses assigned from your primary router or are you using static IPs? If static IPs, are they set outside of the DHCP IP range set on your primary router?
