epa0506
Mar 20, 2018Aspirant
NETGEAR universal wifi extender
Hello, I have a Netgear universal wifi range extender model #: WN3000RPv3 that I am trying to connect to an iPad. When going to the mywifi site, it cannot access the page, even though the ipad is...
jvasanth1984
Mar 20, 2018Virtuoso
Hi epa0506,
If it is prompting you to create an account by inputting e-mail address, password, confirm password and choose 2 security question and answer same, you are in right page. Once you create the account to login to extender, you can access its settings. Do you have trouble connection Ipad to extender? What exactly happens when you attempt to connect?
- epa0506Mar 21, 2018Aspirant
Thank you for getting back to me!
It does not prompt me to create an account, however it acts as though I have already created one, which I have not. It will say the ipad is connected to the wifi, but when accessing a site, it prompts me to enter the username and password for the netgear extender.
- jvasanth1984Mar 21, 2018Virtuoso
Hi epa0506,
Try to reset for 30 seconds. If you still encounter the same issue, try ON/OFF reset to see if it bring it to factory settings. During setup, try to skip it by choosing "Setup later" during selection for EXtender/AP mode and check if firmware is latest. If not, manual update the firmware to see if that helps. You may need to run setup after firmware upgrade to configure extender with the router.
- epa0506Mar 26, 2018Aspirant
Thank you! I will give this a try.
