cleo20
Feb 27, 2017Aspirant
netgear universal wifi range extender wn1000rp-changed router need to change extender to new router
We changed our router. The booster still called itself my old router so I did a factory reset. I connected to netgear_ext but when I try to get to mywifiext.net it tells me that the site can't be rea...
cleo20
Mar 04, 2017Aspirant
Thank you so much. I am afraid that I don't understand what you are telling me to do. I don't see an ip address on my extender. Can you tell me where to look?
DarrenM
Mar 06, 2017Sr. NETGEAR Moderator
Hello cleo20
Typically in the Router settings if its a Netgear router there should be a page called Attached devices and it will tell you the IP address It could be called something different with other routers.
DarrenM
