Lozzie
Jan 12, 2019Follower
Netgear Wi fi extender EX3110
I have connected my wifi extender to my router but when I try to connect to my network with _2G EXT or _5G EXT using the network key, it won’t connect and says that it is incorrect. Any suggestions wh...
Christian_R
Jan 17, 2019NETGEAR Employee Retired
Hi Lozzie,
If you log into the extender's user interface, you'll be able to see the network security for both bands. Please refer to the following article:
https://kb.netgear.com/000037341/How-to-find-the-Extender-WiFi-network-password
~Christian
seemook
Apr 17, 2019Aspirant
Hey,
Im having the same problem, cant login into _ext2 or _ext 5 with router password as it says it is incorrect.
Extender says its connected to router but wont connect to my device as i cant pass the WPA2 security (should be router password) so i am unable to get into the extenders settings.
What do i do?
- Christian_RApr 19, 2019NETGEAR Employee Retired
Hi seemook,
Thanks for reaching out. Have you gotten a chance to check the article I linked earlier in the thread. If not, please perform the following steps and let me know the outcome.
~Christian- seemookApr 23, 2019AspirantThanks Christian,
Like I said previously, I can’t get into the extenders settings using the procedure in the link you posted. My problem is that the router is asking for a password to link to the extender before I can do anything. This is not the router network password, and is not the password on the back of the extender! Any other suggestions?
F
