RobTripp
Sep 27, 2015Initiate
netgear wifi extender wn3000rp - cannot access the main pc from the wifi laptop
I have networked a laptop via wifi to a PC using a HomeHub and the WN3000RP. If I connect the Laptop via this 'Ext' connection I cannot access the PC, but can see it in the network list. If I conne...
Linda92714
Sep 27, 2015Aspirant
I've been having the same problem for two weeks. My router is working fine. My iPhone and iPad find the Extender, CG3000D-1CXNAS, and seem to connect to it, but EVERY website asks for authentication - espn.com, apple,com, etc. Exception is Yahoo, which says it cannot connect to the server. I have done a factory reset; have said "Forget this Network", then re-entered my password and was able to JOIN the network, but same results many times.
RobTripp
Sep 28, 2015Initiate
Noted.
I found Netgear Genie on the Netgear site and installed it. This gave me a view of the network overall using the 2 wifi connections for the laptop: the Hub and the Extender (Ext). It was obvious that the extender was being blocked by a Firewall (Norton IS 2015) so I wrote a new traffic rule for each computer specifically allowing in/out communication between the 2 computer identified specifically by IP adress of each. I then moved that rule to the start of each PC's NIS Traffic rules (as everything else is subordinate. I works! Netgear Genie takes a few moments- minutes to find all the devices, but it worked.
COuld your problem be a 'rule' issue?
Here's the link to Netgear Genie:
http://www.netgear.co.uk/home/discover/apps/genie.aspx
