RobTripp
Sep 27, 2015Initiate
netgear wifi extender wn3000rp - cannot access the main pc from the wifi laptop
I have networked a laptop via wifi to a PC using a HomeHub and the WN3000RP. If I connect the Laptop via this 'Ext' connection I cannot access the PC, but can see it in the network list. If I conne...
Linda92714
Sep 27, 2015Aspirant
I've been having the same problem for two weeks. My router is working fine. My iPhone and iPad find the Extender, CG3000D-1CXNAS, and seem to connect to it, but EVERY website asks for authentication - espn.com, apple,com, etc. Exception is Yahoo, which says it cannot connect to the server. I have done a factory reset; have said "Forget this Network", then re-entered my password and was able to JOIN the network, but same results many times.
nhann
Sep 30, 2015NETGEAR Employee Retired
Thank you RobTripp for sharing your steps!
Hi Linda92714,
Let us know if RobTripp's steps work for you.
You can also try temporarily disabling your antivirus to see if your network issue is being affected by the firewall.
