Liz-S
Aug 03, 2018Aspirant
Netgear Wifi range extender work with Linksys Velop system?
Does anyone know if I can use a wifi extender with the Linksys Velop mesh network? I need to set up a VoIP phone, which has to be connected to the network via ethernet. We have no ethernet wiring in ...
PreetiM
Dec 28, 2018Aspirant
Instead of adding range extender to the network, add new Velop Node to the network. This will give you more coverage as well as good wifi network speed. Usually range extender will half the network speed.
Dec 28, 2018Guru - Experienced User
A Netgear Triband extender won't (assuming it is close enough to connect to the router mesh over 5 ghz).
I agree that Liz-S should look at that option first.
