amfoley's avatar
amfoley
Follower
Aug 22, 2017
NetGear WiFi Range Extender
This was set up and had been working fine for quite a long time.  all of a sudden it no longer remains connected to my router.  If I go throught the web interface it refuses to connect to my router.  I have to move it into the same room to get it to reconnect.
Any suggestions how to stop this from happening.  An extender next to my router is pretty useless.
Thanks.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello amfoley
    Have you tried to factory reset the unit by holding the reset button for 10 seconds and then try the setup again.
    DarrenM
