tlm1942
Oct 03, 2018Follower
netgear wireless usb adapter wg111v2
can netgear wireless usb adapter wg111v2 be used to connect to a printer to make it wireless?
Oct 03, 2018Guru - Experienced User
No. You can find some wireless print servers out there that can do this trick - for instance
https://www.amazon.com/dp/B00M77UME8
https://www.amazon.com/dp/B003CFAU0U
https://www.amazon.com/dp/B00NMUJ4R0
They might not work with your particular printer. I suggest looking into getting a network printer, that might be a better option.
