ewil
Sep 10, 2023Aspirant
netgear WN2000RPT firmware update - error firmware region! Any solution?
I have a WN2000RPT Wifi Range Extender which is currently running firmware version V1.0.0.24IC. As far as I can tell, it is a v1. According to the status panel, the region is "United States". ...
schumaku
Sep 13, 2023Guru - Experienced User
Based on the existing v1.0.0.24, and the list of Previous Versions, I suspect it's a WN2000RPTv3 – N300 Universal WiFi Range Extender
ewil
Sep 13, 2023Aspirant
Thank you very much for the suggestion - however that didn't help for me.
I downloaded the latest firmware for the v3 - 1.0.1.34. When I tried to upload that file "WN2000RPTv3-V1.0.1.34.img", I get an error "Error upgrade file module name! (Module name is "WN2000RPT")"
For kicks, I tried to rename img file, removing the v3 from the name, then I am back to the "error firmware region!" error.
Just in case - this is too much of a jump in firmware versions, I tried the same 2 things with the WN2000RPTv3-V1.0.1.4 firmware, and got the same results.
Thank you again for the help, but I am still stuck and unable to do the firmware upgrade.
See below for the relevant portion of the status screen of my device.
- ewilSep 27, 2023Aspirant
I was hoping that I would be able to get a solution for this, now my hope is fading (unfortunately).
- plemansOct 06, 2023Guru - Experienced User
When it auto-checks for firmware, does it find any?
I'm curious if this is a version supplied to ISPs because of the IC after the firmware version.There were a few routers/extenders that were directly supplied to ISP's that had specific firmware on them.
- ewilOct 06, 2023Aspirant
Thanks for reaching out. No, it does not find an upgrade during the automatic checking.
If this indeed started out life as a routers/extender that was directly supplied to ISP's, does that mean I am out of luck and there is no upgrade path?
Mostly the performance has been good, but I have had instances where it totally froze up and wanted to first see if a firmware upgrade would help.
Thank you again for the response,
Evan
