ewil
Sep 10, 2023Aspirant
netgear WN2000RPT firmware update - error firmware region! Any solution?
I have a WN2000RPT Wifi Range Extender which is currently running firmware version V1.0.0.24IC. As far as I can tell, it is a v1. According to the status panel, the region is "United States". ...
ewil
Sep 13, 2023Aspirant
Thank you very much for the suggestion - however that didn't help for me.
I downloaded the latest firmware for the v3 - 1.0.1.34. When I tried to upload that file "WN2000RPTv3-V1.0.1.34.img", I get an error "Error upgrade file module name! (Module name is "WN2000RPT")"
For kicks, I tried to rename img file, removing the v3 from the name, then I am back to the "error firmware region!" error.
Just in case - this is too much of a jump in firmware versions, I tried the same 2 things with the WN2000RPTv3-V1.0.1.4 firmware, and got the same results.
Thank you again for the help, but I am still stuck and unable to do the firmware upgrade.
See below for the relevant portion of the status screen of my device.
ewil
Sep 27, 2023Aspirant
I was hoping that I would be able to get a solution for this, now my hope is fading (unfortunately).
