ewil
Sep 10, 2023Aspirant
netgear WN2000RPT firmware update - error firmware region! Any solution?
I have a WN2000RPT Wifi Range Extender which is currently running firmware version V1.0.0.24IC. As far as I can tell, it is a v1. According to the status panel, the region is "United States". ...
ewil
Sep 27, 2023Aspirant
I was hoping that I would be able to get a solution for this, now my hope is fading (unfortunately).
Oct 06, 2023Guru - Experienced User
When it auto-checks for firmware, does it find any?
I'm curious if this is a version supplied to ISPs because of the IC after the firmware version.
There were a few routers/extenders that were directly supplied to ISP's that had specific firmware on them.
- ewilOct 06, 2023Aspirant
Thanks for reaching out. No, it does not find an upgrade during the automatic checking.
If this indeed started out life as a routers/extender that was directly supplied to ISP's, does that mean I am out of luck and there is no upgrade path?
Mostly the performance has been good, but I have had instances where it totally froze up and wanted to first see if a firmware upgrade would help.
Thank you again for the response,
Evan
- plemansOct 06, 2023Guru - Experienced User
If its an ISP specific device, you probably are sol.
I'm not saying it is, but I don't see that specific firmware anywhere and the lettering after the version is suspicious.
I wouldn't invest to much time in that device as its a pretty old/slow extender.
A half-decent dual band extender is going to be significantly higher performing that it is.
