PsySciGuy
Dec 27, 2015Aspirant
Netgear WN3000RP blocks port forwarding
External (Internet) access to a WiFi IPCamera using port forwarding through Cisco router works fine Changing the WiFI IPcamera's SSID choice to the extended network of the WN3000RP works fine from d...
PsySciGuy
Dec 29, 2015Aspirant
Looks like the problem is solved. Updated software from xxx.32 to xxx.64. Works correctly now.
