curtm
Jul 01, 2014Aspirant
netgear wn3000rp not finding 802.1
This wireless range extender finds the WiFi network I would like it to connect to, but says it has WPA2 security, and only allows for the passphrase to be entered. When I try to connect to the WiFi...
fordem
Jul 01, 2014Mentor
What exactly are you having trouble with - connecting the range extender to your WiFi network?
When you speak of trying to connect to the WiFi directly - what are you connecting to and what are you connecting with?
