weyd
Nov 20, 2018Aspirant
NETGEAR WN3000RPv3 Problème de wifi
Bonjour, cela fait des années que j'ai le Répéteur WiFi N300 Modèle WN3000RPv3 dans les jours qui suivent . Je me suis souvenu à plusieurs reprises (connexion via WPS étant faite), le réseau est dé...
Nov 20, 2018Guru - Experienced User
Does your router support WPA2-PSK? If so, you should change the router wifi to use it.
I believe that is a suggestion. Is the extender working ok now?
- weydNov 21, 2018Aspirant
humm that's a good question, I don't know. I'm not a specialist in informatique, I know just on/off and buy a router, thats my skills...
I don't know what is support WPA2-PSK sorry ...- StephenBNov 21, 2018Guru - Experienced User
You'd need to be able to log into your router's admin UI, and then look at the WiFi settings.
There are several options for WiFi security - including several old methods that aren't secure any more. WPA2-PSK is the one you should be using now - and apparently you aren't.
