Len-B
Sep 09, 2018Follower
NETGEAR WN3000RPv3
Hi All,
I used my WN3000RPv3 N300 WiFi Range Expender for a few months and it worked fine. Now the router has been changed (different provider). I should reconnect the new router (with the new address). The Extender's two LED on te left a green indicating that it recognizes the rouuter but there is no connection to the Client (the Computer). Could you help, please?
Thank you
Len
1 Reply
The simplest approach is to try resetting the extender, and setting up again. The user guide explains how to do that (in case you've forgotten the steps). http://www.downloads.netgear.com/files/GDC/WN3000RPV3/WN3000RPv3_UM_25Aug2015.pdf
