Len-B's avatar
Len-B
Follower
Sep 09, 2018
NETGEAR WN3000RPv3
Hi All,
I used my WN3000RPv3 N300 WiFi Range Expender for a few months and it worked fine. Now the router has been changed (different provider). I should reconnect the new router (with the new address). The Extender's two LED on the left are green indicating that it recognizes the rouuter but there is no connection to the Client (the Computer). Could you help, please?
Thank you
Len
  • Hi Len-B,
    Welcome to the community!
    Since it is a new router and a new network, it is best that you reset the extender back to factory settings as described on page 38 of the user manual on this link and go through the installation process as described here.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Len-B,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Len-B,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
