micmic
Nov 10, 2016Aspirant
Netgear WN3100rpV2 and Asus Zenbook UX310UA
Hi, I have a netgear WN3100rpV2 that works fine. I can use it as a repeter or a hot spot. But for some reason, i can't connect my laptop (asus zenbook ux310UA) to it. the connection failed befo...
- Nov 18, 2016
Hello,
I solve the problem few hours after i posted it by using your Netgear genius app, so i could connect to my wifi connection without any pb.
DarrenM
Nov 14, 2016Sr. NETGEAR Moderator
Hello micimic
Do you happen to have the SSID name the same on the router and the extender if so that could be causing the issue may need to rename one also make sure your are using WPA2 security.
DarrenM
- micmicNov 18, 2016Aspirant
Hello,
