ESA1178's avatar
ESA1178
Netgear WN604 Access point install
Hello all!
I have a wifi home network setup. My PC is physically connected to the router, however all other systems connect via wifi.
My hous is large and L shaped. The master bedroon is on the far side of the L and the eouter is in the middle..
However, wifi signal is not the greatest, and I have even tried using a plug in extender, with not much success.
I am now also using ROKU in the bedroom, and it is connected to wifi, service is slow...
I have run a CAT5 cable from the router through the attic to the bedroom..
I want to connect the CATS5 from the router to the access point, and the ROKU to the access point with cable).
Then I would like to access my home wifi thru the access point....
I am trying to follow the install directions, but I have only got to the part where I connect the access point to my PC, and then power up the
access point. I then open browser and type HTTP://192.168.0.100
But I get: This webpage is not available...
Thanks in advance for your help!
Mark
Sacramento, CA USA
