GraemeBR's avatar
GraemeBR
Follower
Jun 11, 2019
NETGEAR WNDA3100-200PES N600 with a Panasonic Viera TX-P42UT30B TV
Hi
i bought a NETGEAR 11AC 1200Mbps Dual Band Gigabit 802.11ac (300 Mbps + 900 Mbps) WiFi Range Extender with External Antennas and Extra Power Outlet
works well
I have a Panasonic Viera TX-P42UT30B ( old but i like as 3d & we like 3d )
I bought a
NETGEAR A6210-100PES AC1200 802.11ac Dual Band (300/867 Mbps) High Gain Wi-Fi USB 3.0 Adapter
& a
NETGEAR WNDA3100-200PES N600 802.11n Dual Band (300/300 Mbps) WiFi USB Adapter
as a kind of wireless LAN replacement.
Please help me connect as obviously not a PC/Laptop so no CD install.
Are thes right ones to buy or is there something else? WHich?
Please NETGEAR super guys how do I connect ? Thanks
1 Reply
  • plemans's avatar
    looks like you posted this twice.
    You can plug it into your tv but it isn't going to work. Both adapters are compatible with windows.
    Your tv has a usb port but plugging a wifi adapter into it isn't going to make it work.
    From the sound of it, you're trying to have better streaming. You could always hardwire the tv to the extender or even use a powerline adapter for a hardwired connection.  Or you could purchase a smart device (roku, apple tv, android tv device) with built in wifi capabilities. Might be a route to check into as the Viera doesn't have a whole lot for smart features and you could get a decent roku and wireless capabilities for slightly more than a new wireless adapter.
