justin619's avatar
justin619
Network Extension
I have recently started my office, looking to extend my network to different rooms.
I am thinking of setting up WiFi for each and evry room individually.
What could be the best way to achive the same.
Can anyonw help me with any sort of documentation ?
Thanks
Justin
  • plemans's avatar
    how many rooms?
    You could always go with somethink like orbi
    • justin619's avatar
      justin619
      I have the main WiFi router in the middle room which is kind of meeting hall / conference hall.
      After that, I have 8 rooms surrounding the hall.
      So it is something lke that.
      Thanks
      • plemans's avatar
        I've read of people using up to 6 orbi satellites.
        And you HAVE to have one in each room?
        That's a bit expensive and would put the satellites to close to each other as they recommend 30ft between satellite/router
