timandadam
Sep 26, 2017Aspirant
Network password
Hi i have set up my Extender and connected to to my Virgin Media network ok. The extender transmitter is in a separate garden room. I am using a Mac book pro, iPhone 6 and iPad Pro. As I move from th...
DarrenM
Sep 28, 2017Sr. NETGEAR Moderator
Hello Timandadam
The extender creates a separate network and does not hand off the devices so if you have the extenders SSID the exact same as the main network it could be causing the issue.
DarrenM
timandadam
Sep 29, 2017Aspirant
Hi Darren
thank you so much for replying / helping me on this ! I get your point on this. However I'm not at all technical. I followed to instructions to set up the netgear extender connecting it to my Virgin Media WIFI
So the extender automatically sends out the same Network ID as the main router. So when you enter the garden room with a new device and search for WIFI you see the Same Virgin Media network from the extender and then you get the prompt asking for the password.
Does the fgarden room need the netgear settings changing to create a new network I'd and password ? If so Howe do i do this. SO far i have followed the instructions and not been asked to creat a new password or net work name ?
Thanks again for any help
- DarrenMOct 03, 2017Sr. NETGEAR Moderator
Yes for the best results you would need a new name and password. While connected to the extender you will want to visit www.mywifiext.net and log into the unit with admin/password. then you can change the name and the password in the wireless settings.
DarrenM- timandadamOct 30, 2017Aspirant
Hi Darren
many thanks :) i got it working with your help.
all the very best Tim
