Ploymorph's avatar
Ploymorph
Network Printing
Network Printing     I have a Netgear EX6200 Range Extender, two computers running Windows 10, three computers running LinuxMint and a printer connected to the Range Extender.     I can print...
  • Ploymorph's avatar
    Ploymorph
    Jul 29, 2015
    Thanks for your reply.
    It is a shame that Linux is not supported since the hardware is so good.   Everything works well on Windows 10 computers.
    I am sure that you know of a solution even if it is not official ;)
    Care to share?
    I will try to connect the Linux computers through a Windows computer and see what happens.
    Thanks.
