Tarkus's avatar
Tarkus
Tutor
Oct 11, 2018
New AC1900 (EX7000) can't get on the local network
I just bought a second EX7000 to use as an ethernet-connected WAP at one corner of my home, I have an existing EX7000 at the other end of the house which does the same job and works perfectly. My home network is 192.168.0.x and addresses are handed out via DHCP. However when I power up the new EX7000 it does not appear in my network when I scan it with Advanced IP Scanner. I know the new WAP is functioning because when I restore factory settings and power it up I can see NETGEAR_EXT in my local wifi networks.
If I edit my dhcp config to assign a fixed IP address based on MAC address it is not assigned - I've tried both MAC addresses on the pullout label and every ethernet slot on the device.
The first WAP setup easily, what's up with this one?
  • You might try updating the firmware to 1.0.0.66.  I'd avoid 1.0.1.78 for now, there are a lot of people reporting issues with it.
    The subnet mask should be 255.255.255.0.
    Perhaps also try the smart setup path, as that might be needed for the system to determine that you are setting it up as an AP instead of as an extender.
  • StephenB's avatar
    What firmware are you running?
    There are quite a few issues being reported with 1.0.1.78, so if you are running that you might try downgrading to 1.0.0.66.
    • Tarkus's avatar
      Tarkus
      Tutor
      Hi
      This is out of the box
      Hardware Version: EX7000
      Firmware Version: V1.0.0.62_1.0.122
    • Tarkus's avatar
      Tarkus
      Tutor
      My home network's router is 192.168.0.254 and my gateway is 192.168.0.1 (an ubuntu NUC running DHCP and DNS). The DHCP server serves up IP addresses in the range 192.168.0.129-250.
      Here's what happens with the new (hopefully) WAP.
      1. I connect an ethernet cable from the router. I know the port works.
      2. I switch the EX7000 on. After about 30 secs it settles down with the LAN port and extender LED's green, all others off.
      3. I can see NETGEAR_EXT in the list of wifi networks, so I connect to it with my phone and open a browser at mywifi.ext.
      4. It says I am not connected to my extender's WIFI network.
      5. I follow the link to log in directly to the EX7000 and login with my recovery username and password. (This is a new one, not the same as that used for the existing WAP).
      6. It says I am not connected to my router, do I want to use the genie or connect manually.
      7. I say I want to set it up myself. It goes into the smart setup page (which is where I see the firmware version I reported earlier), but I go instead to the device menu at the top left corner of the page.
      8. I open the settings option, pick Wireless, scroll past the 2.4G and 5G wifi settings and open the IP Address section.
      9. The device is set to pick up an address dynamically from the router but I can see that the address it has been given is 192.168.1.250. Nothing in my network would allocate this address.
      10. I chage it to use a static IO and assign it 192.168.0.6, gateway as above, DNS server 8.8.8.8
      11. Am I sure I do not want any security? Am I sure this address is in the correct subnet? I say OK to these (I'll change the network security later)
      12. My browser page asks me to login again, so I do.
      13. Go back to step 6.
      • StephenB's avatar
