Tarkus
Oct 12, 2018Tutor
New AC1900 (EX7000) can't get on the local network
I just bought a second EX7000 to use as an ethernet-connected WAP at one corner of my home, I have an existing EX7000 at the other end of the house which does the same job and works perfectly. My hom...
- Oct 14, 2018
You might try updating the firmware to 1.0.0.66. I'd avoid 1.0.1.78 for now, there are a lot of people reporting issues with it.
The subnet mask should be 255.255.255.0.
Perhaps also try the smart setup path, as that might be needed for the system to determine that you are setting it up as an AP instead of as an extender.
Oct 14, 2018Guru - Experienced User
Tarkus
Oct 14, 2018Tutor
Thank you
I updated the firmware to 1.0.0.66 and restarted the whole process. Allocating the correct IP address via DHCP is now happening, and smart setup is no longer complaining that the device is not connected to the router. The network is networking.
- StephenBOct 14, 2018Guru - Experienced User
Thx for updating us on the outcome :smileyhappy:
