Mr_Fatty
Apr 14, 2014Follower
New Extended _EXT Network
Hi, yesterday I just purchased a WN3000RP range extender and did the install using Netgear Technical Support. The part that confused me is that it created a new network connection, using my home netwo...
jmizoguchi
Apr 14, 2014Virtuoso
You can rename to be same SSID even you get the alert when you do
