SparkleMania
Oct 22, 2015Tutor
New router & password, can't connect WN2500RP
I have searched the help here, but can't find a solution ... my landlady got a new router with a new password. I can connect with hard wire but also need my wireless extender to work. From what I ca...
TheEther
Oct 26, 2015Guru
Please open the link to the manual that I provided above and follow the instructions on either page 15, 22 or 33.
- SparkleManiaOct 26, 2015Tutor
The web links to www.mywifiext.net and www.mywifiext.net take me to error pages. Apparently what I need is to somehow log into Maintenance ->set password, but the web page it says to go to does not work.
- TheEtherOct 26, 2015Guru
Did you first connect your computer to the extender's Wi-Fi network (NETGEAR_EXT) or Ethernet port? You must do that in order for www.mywifiext.net to work.
I keep trying all the things in the instruction manual, and that I can find online, I even reset the device to factory settings, and I keep getting "connection refused" or error messages when I try to find some way to get into Maintenance. The extender sees the router, but I can't get into the extender to tell it the new router name and new password.
- SparkleManiaOct 27, 2015Tutor
I am watching the video and same with all the things I've done ... it SHOULD launch the wizard but does not. And I could not figure out how to launch that Genie page manually. I would enter the web adderess, and, as mentioned, get an error page. *** My whole problem has been I could not launch Netgear Genie!!! ***
But the video refered to it as a "wizard" so when I did an internet search for "Netgear Setup Wizard", I FINALLY found a link to open it!!!!!
http://www.mywifiext.net/IA_frame.htm
I am now set up!! And my laptop is now connected. Now to set up my 5 other devices!!!
