congaman59
Dec 03, 2016Aspirant
New to range extender set up
I reciently bought a wn2500rp v2 dual band repeater. I am trying to set it up to work with my Lynksys E4200 dual band wireless router. that router is connected to the router from Comcast. I have neve...
DarrenM
Dec 06, 2016Sr. NETGEAR Moderator
Hello congaman59
This article may be helpful for the setup.
DarrenM
- congaman59Dec 14, 2016Aspirant
I tried to use the article steps but when I got to number 4 it didn't find my local wi-fi setup.
- DarrenMDec 16, 2016Sr. NETGEAR Moderator
Hello congaman59
Do you had the SSID hidden on the main network? Also try to set up the extender beside the router then after you get a connection move it to where you want it.
DarrenM
