dibster's avatar
dibster
Follower
Jul 17, 2016
New Visio TV shows strong WiFi connection to extender but Netflix, etc. won't connect
I have had this Netgear WiFi extender for two years, works fine to connect iPhone, iPad, computers. Sett up new Visio TV which shows strong (5 bar) connection to correct extender SSID.  But apps such as Netflix, Amazon, etc. will not connect even though each shows strong signal!?
Local cable guy said he has heard of problems with TVs connecting via extenders. Asked if Extender might have some sort of firewall built in which prevents TV from truly connecting.
Any ideas or suggestions greatly appreciated.
1 Reply
  • Does your TV have a built-in test to check the network connection?  It should also display details about the connection, like whether it was able to obtain an IP address.  Have you checked those settings?
