Chesty
Aug 10, 2016Aspirant
Nexus 7 (2013) tablet wifi connection issues
DarrenM
Aug 15, 2016Sr. NETGEAR Moderator
Hello Chesty
The first thing I would try is to factory reset the extender and try the setup again. After that I would tell all of your devices to forget the old ext network. Then try to connect again also you may want to check for the latest firmware for the extender.
DarrenM
Chesty
Aug 18, 2016Aspirant
I made all efforts expressed here. Still a failure. BUT resolved the matter by buying Netgear ex6200 all is now well!
