Cheshire_vinny
Jul 06, 2022Aspirant
Nighthawk 7700 internet not working on all devices
Hi, I have recently set up my EX7700 and it is extending my Virgin Hub 3 router, I have it set to same SSID details for a seamless transfer, however not all the devices when transferring to the exten...
Cheshire_vinny
Jul 07, 2022Aspirant
hi,
thanks, tried your suggestion last night and lasted about an hour and the 2 devices again "connected no internet", soon as I move downstairs and the devices pick up the USP router then all good and speeds of 200+, i have seen a few threads on here saying the same but just cant find a solution....
Jul 07, 2022Guru - Experienced User
You can try going into the virgin hub and setting the extender with a static ip address.
I haven't really found a good solution for the virgin hub 3 as there's been numerous posts on here and virgin about adding extenders to it.
The ISP supplied routers really give routers a bad name.
- Cheshire_vinnyJul 07, 2022Aspirant
So have done that via the extender and the devices with the issues got internet connectivity back! Lets see if this holds up over the next 24hrs, thanks for the suggestion and help, will let you know.
sadly that lasted 6 hours then off they went again….time to admit defeat and send it back and try another brand. Thanks for your help though.
- plemansJul 07, 2022Guru - Experienced User
You might check with virgin. Yours isn't the only device thats had issues with that router but I think they make their own extender
