CharlieO69's avatar
CharlieO69
Nighthawk AC1900 Extender and Reolink Argus camera
I am trying to get the extender to link with the camera.  No buttons to push or PIN for the camera.  I use my mobile for the Reolink app and when it get to the handshake to the extender it doesn't connect.  Is the app's attempt to link to the extender the equivalent  of the WPS id?
  • The camera must be linked to the extender, and then the camera must be linked to some cloud environment -  that's what the key in the App is for most likely.
    • The setup in the app to link to the extender just fails.  I even went into the extender to treat it like a button push to ID the camera but even that didn't work.  The extender will take a PIN but I don't see one for the Reolink.  My phone showed up on the extender all on its own...NADA for the cameras!
      • schumaku's avatar
        schumaku
        The Extender would provide a PIN when it's up to connect (associate) a device. Nothing to change on the extender. Again, it's about to configure the cameara so it can associate with the wireless name (provided by the extender), not to change anything on the extender.
        The Use Reolink App to configure wireless settings does show a different process - by connecting the camera to the switched network (Ethernet port).
        Provide a link to the process you try to follow.
