Bombadil
Feb 15, 2016Follower
Nighthawk AC1900 Model R7000 Won't connect to Technicolor router
Hi, Just tried to connect my router (Technicolor TG788vn v2) to my brandnew NETGEAR Nighthawk AC 1900 Range Extender (EX7000). OS:Windows 8.1. The connection is allright using WPS on the extende...
DarrenM
Feb 19, 2016Sr. NETGEAR Moderator
Hello Bombadil
Are you using WPa2-psk as the security type on your router? you may want to try a different security type and see if the password will work. Also you may want to factory reset the EX7000 and try to go threw the setup again.
DarrenM
