ernsol's avatar
ernsol
Initiate
Jan 28, 2023
Nighthawk AX8 (AX6000) Extender Power Cord
My dog chewed up my Nighthawk AX8 Extender (AX6000) power cord.  Where I I get a replacement?  Or if 3rd party, what specs do I need to look for?  Any help is appreciated.
  • I'm betting if you look on the label for the extender it says EAX80
    If so, it should be the matching to what I listed.
  • plemans's avatar
    If you're talking the EAX80, it uses part number 332-11494-01
    Model number ad2150f10
    it outputs 12v at 3.5amps.
    this is off my EAX80's info.
    • ernsol's avatar
      ernsol
      Initiate
      Hi plemans!  I really appreciate your quick response.  The nameplate on my Extender does not have a "R" only AX8 and below it has AX6000.  I do know from the product literature on the Netgear website that it is a 12V, but no other specification is shown.  I am guessing the power cord you mention would probably work.  Once again, thank you for your help.
       ernsol
      • plemans's avatar
