glinda3175's avatar
glinda3175
Nighthawk eax20 shuts off Wi-Fi to house when connected to ethernet cable
Newbie here - I’m trying to set up Wi-Fi in a separate building from my house, and have run an Ethernet cable from my router to the building. When I plug the eax20 in, it works OK (the signal goes up and down) and the WiFi in house shuts off. I’m assuming this is a settings issue?
  • plemans's avatar
    Did you setup the EAX20 in access point mode?
    • glinda3175's avatar
      glinda3175
      At first I set it up as an extender, and the WiFi in the house shut off. I then set it up as an access point and the WiFi shut off again.when I unplugged the eax20 it came back on.
      • plemans's avatar
        The extender shouldn't be impacting the router at all when setup in access point mode or messing with the primary routers wifi at all.
        What router is it connected to?
        What method of setup are you using? (the app, installation assistant, wps)?
