JCoco06178
May 23, 2018Aspirant
NIghtHawk EX7000
HI i've had this NightHawk Ex7000 since Novmber to extend my wifi in my other bedroom & my living room is right underneath the bedroom and it was working just fine all this time but now my roku in th...
ronnymac32
May 24, 2018Guide
That stinks. So the 2.4ghz band just drops? And nothing can connect to it? Have you tried swapping the wifi channel? I find using Netgear's Wifi Analytics app on the phone quite useful. You can see which channel has least interferance and try that?
Update: I found this while I was digging for my beamforming issue..
Seems like it's a common issue you're having. I'd try some channel swapping, maybe using a static IP, or messing with the Fastlane settings. Right now I have an issue with trying to turn off beamforming. Hope this helps!
JCoco06178
May 25, 2018Aspirant
Yes it wont show up on any phone , computer , tablet , roku the only the one desktop thats connected to the extender dircetly works with the 2.4G but the wifi part doesnt work the only way i found that it comes back is if i power it off & on its set on auto for that channels i try what you said i really dont know much and extender channels and how is works.
Thanks for the help
