wshelton59
Jun 07, 2018Follower
Nighthawk EX7300 - No Internet
I can connect my NETGEAR Nighthawk X4 AC2200 WiFi Range Extender to the Asus RT-AC3100 router but am unable to connect from the extended wifi connection to the internet. I have factory reset the mode...
- Jun 11, 2018
Hi wshelton59,
Welcome to the community!
1. What is the firmware version of the extender?
2. Are your other devices able to go online when connected to the main router?
3. Please make sure that the extender is excluded from any filtering feature you have enabled on the router.
Dexter
Community Team
DexterJB
Jun 14, 2018NETGEAR Moderator
Hi wshelton59,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
