bargemans's avatar
bargemans
Follower
Apr 08, 2021
Nighthawk EX7500
Hi
Im trying to connect the extender to my BT hub
It connects through 2.4Ghz but not through 5Ghz
The BT hub only offers channels 36, 40, 44 & 48 at 5GHz
How do I force the extender to connect through one of these channels and not the default channel 100?
1 Reply
  • plemans's avatar
    Which bt hub do you have?
    Are you installing using the installation assistant or using WPS?
    i'd try factory resetting (push and hold reset for 7-15 seconds while its powered on) and then install using the installation assistant.
    That allows you to select the network when setting up 5ghz.
