Colinclement
Jan 10, 2023Tutor
Nighthawk EX7700 loosing settings
Hi my Nighthawk EX7700 looses its settings if my router drops like if I reboot it. I then have to reset the unit and set up again. Is this a known fault. Thank you. Colin. Uk
Colinclement
Jan 21, 2023Tutor
Hi Oliver
Thank you for reaching out to me. The firmware is 226 which is exactly the same as my other unit which is the same model that I use in another part of the house so it can’t be software ! You say try a different version but this is not something I can do from the app. That just updates to latest version. If I reboot with either the app, or power button the unit comes back on eventually with no lights on and does not show on the app. This is definitely a hardware issue but I know you are the expert. I appreciate your help and advice. Regards. Colin.
calia1120
Jan 28, 2023Initiate
It's a known issue with earlier hardware - ran into it myself. Firmware rollback solved the problem for me, make sure to avoid the .210 as well because it has the same problem - https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EX7700-keeps-factory-resetting-every-few-weeks-Loses-all/m-p/2213644
