mpb65
Sep 09, 2021Tutor
NIghthawk Extender - Blinking Red Power Light
I unplugged my router as I wanted to change its location.
Now when I plug it in the rear power light turns from Green to Red(Blinking)
And all the front White lights are blinking.
Tried the reset button, but nothing.
HELP PLEASE!
Please visit and post about this over in the WiFi Extender forum:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
I notified a moderator to move it. in the meantime,
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
