datadr93
Jul 17, 2018Initiate
Nighthawk mesh vs Orbi mesh
I currently have a dual band X4S NightHawk R7800 router along with one X4S tri-band extender (AC2200). Looking to increase WiFi connectivity in home (tri-level house) for over 20 devices (incuding ca...
DexterJB
Jul 19, 2018NETGEAR Moderator
Hi datadr93,
Welcome to the community!
Either option will theoretically yield the same result setup-wise. The only reason to pick one over the other is if you want/require something very specific from it (i.e. total bandwidth difference, ease of setup, aesthetics, expandability). This is disregarding the cost difference.
Dexter
Community
datadr93
Jul 23, 2018Initiate
Thanks Dexter for validating backhaul config. I opted for the Orbi, 2 satellites, and maintained my plug-in Nighthawk x4s for the garage. My outdoor cameras work with no lag now. Router is in basement with 2 satellites on other 2 levels. Signal is not super strong going to garage but with the extra plug-in works great now.
From what I read, the Orbi plug-in not as strong as the x4s thus decided to keep. And the backhaul is working flawlessly with the Orbi components in a nice star configuration.
