stevehl
Sep 15, 2018Follower
Nighthawk Model: EX7500
My computer takes a long time to see Netgear_ext SSID and when it eventually does it only gets 2 bars. The signal is very flaky. I can sometimes get to www.mywifiext.net ...
Just_some_guy
Sep 22, 2018Aspirant
I wouldnt be surprised if it is. The 7500 has alot of issues. Not sure if its craming parts into a smaller form factor but the one I got wouldnt work. If you take a look at the amazon reviews you will see that all the mesh products reviews are bundled together. This way all the products bennefit from a 5 star review even though only 1 of them actually works. Go check it out. All the negative reviews are for the EX7500. All the positive ones are for the EX8000. I replaced my 7500 with the 8000 and all the issues went away.
The 7500 is trash.
