DavidSD
Jan 19, 2017Aspirant
Nighthawk R6700 - add access point
I have issues with WiFi signal strength in my daughters room. I have tried extending the signal with a AC1200 extender but it did not help. Her laptop will only handle the 2.4 range. I was wondering ...
michaelkenward
Jan 19, 2017Guru - Experienced User
As well as running a LAN cable, another, tidier, option is to get a Powerplug duo that will deliver wifi as well as LAN to her room.
Powerline Networking | Powerline Ethernet | NETGEAR
Maybe her laptop can also connect to the LAN port on the plug. That could be even better than the wifi.
