krick1
Jan 01, 2024Aspirant
Nighthawk Range Extender App
I got the 1600 model range extender and couldn't even set it up. The app refused to connect/log the extender into the 5.2gHz band of my Bell Home Hub 300 router. Tried multiple times and repeatedly said the password is wrong, when I literally went back onto my actual SSIN so I could go into the band's wifi settings specifically to screenshot the share QR as it has the wifi password underneath it.
Not clue what model extender you have as you didn't give a model number.
You can try using the WPS method of setup.
or you can set it up using the installation assistant.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
if you need to, To factory reset, push and hold the reset button for 7-15 seconds while powered on. - krick1Aspirant
krick1 wrote:I got the 1600 model range extender and couldn't even set it up. The app refused to connect/log the extender into the 5.2gHz band of my Bell Home Hub 300 router. Tried multiple times and repeatedly said the password is wrong, when I literally went back onto my actual SSIN so I could go into the band's wifi settings specifically to screenshot the share QR as it has the wifi password underneath it.
i got this.. https://speedtest.vet/
