azwebbie
Feb 11, 2018Aspirant
Nighthawk X10 R9000 Router and Nighthawk X4S EX7500 Extender Issues
Just replaced my R8300 with the R9000 (V1.0.3.6) and also using EX7500 (V1.0.0.38). After bringing the EX7500 into the network many wireless devices frequently drop and re-add to the network (monito...
ae6dx00
Apr 07, 2018Guide
I'm having similar issues. Can anyone help?
vfiss
May 02, 2018Aspirant
I'm hving the same issue as well with an apple airport extreme and also when Ex7500 is connected to a nighthawk X10. I have downgraded my EX7500 to EX7500-V1.0.0.36_1.0.53 this morning and checking if the issue persists.
- vfissMay 05, 2018Aspirant
All,
The firmware downgrade didn't resolve the issue. I solved the issue by disabling AUTO channel selection in 2.4GHz. I have set to a specific channel and since then, not problems (it has been 2 days so far). If the status, change, I will let you know.
- DarrenMMay 07, 2018Sr. NETGEAR Moderator
If you are still seeing this issue and are willing to work with our support team please PM me.
DarrenM
- azwebbieMay 07, 2018Aspirant
I have never used "auto" channel selection for the 2.4 and still using the current firmware for the R9000 X10 Nighthawk Router. I simply removed the EX7500 Range Extender from my network and everything is now running fine. Good Luck!
This issue can be closed for me. Thanks
