Riopelle07
Oct 18, 2018Aspirant
Nighthawk X4S AC2200 R7500-100aus not connecting to netgear router
My Wifi extender is not connecting to the internet nor is my Net gear nighthawk AC1900 recognizing it - trying to mesh the internet- reset to factory setting multiple times, power light blue - wps light blue - 5g blue- but router does not show it connected. Need to reset so I can see both - tried using the mywifiext.net - to no avail - saying I am not connected to the internet. Extender does not show up on my phone as a seperate IP address... tried using IP short cut - does not work... NEED HELP!!!! I know there has to be a way to fix. No way to attach via ethernet only via wifi.
- DexterJBNETGEAR Moderator
Hi Riopelle07,
Welcome to the community!
Please make sure you have your device (the one being used for setup) connected to the extender's network. The installation guide on this link may help.
Dexter
Community Team
- Riopelle07AspirantThank you dexter.. but the extender does not show up for us to connect to it at all... we only see the Netgear router..
