Buddy3
Mar 30, 2018Follower
Nighthawk X4s Tri-Band Extender. EX7500
new Nighthawk is does not power up. Unit remains in constant blue-blink power status. Tried reset button, did not fix. Tried power down, no fix.
jvasanth1984
Mar 31, 2018Virtuoso
Hi Buddy3,
Try to do reset for 1 minute when the unit is turned on to see if that helps. If it doesn't, try to do ON/OFF reset and see if that works.
